cmd command
Discussion in 'Programmer's Corner' started by m4lyg0s, Jun 6, 2014.
  1. m4lyg0s
    Apr 17, 2014
    11
    hello people i have some problems with my pc (windoes 8 single language 64 bits)
    a carpet in my documents is in read only
    well i went to cmd and type
    attrib -r C:\eat /s /d
    when i check at my file it is still on read only
    i also change register (explorer) and nothing so far...
    do you guys know something about this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Can you change the attribute by right-clicking the file name and selecting the file's Properties?
  4. m4lyg0s
    Apr 17, 2014
    11
    no, i cant . that is the easy way and did not work , them went to the cmd exe and it did not work either , was thinking it could be a virus , but man if a virus do that i am pretty sure i will not be able to turn on my pc xd
    bertus btw, as i understand the "-" from the "-r" means i am deactivating the read only not resetting it at least that is what it says in the microsoft helping site...
    even the link you provided tells the same thing : "For example, to remove the read-only and hidden file attributes for all files in a directory tree:
    attrib -r -h *.* /s /d"
    but it is not working... :/
  5. djsfantasi
    Apr 11, 2010
    2,905
    878
    What is the file name of the file you are trying to reset?
    As Bertus pointed out, the command you gave will only reset the file "eat" in the root directory - C:\. If "eat" is a folder, it will reset the read only attribute on the folder, but nothing else; it will ignore the /S. You would need to specify additional files using wildcards.
    Please clarify as to the file(s) you wish to reset the read only attribute on and perhaps we can clarify further.
    BTW, the "attrib" command will not prevent the attribute from getting set again. It will change it only.
  6. m4lyg0s
    Apr 17, 2014
    11
    for now it is an empty carpet (moved to documents) and about the /s i will add like 3GB of information will be a bit of everything , dll , exe , note etc (and of course i want all information in there to get uncheck in the read only attrib that is why i was testing /s but with no information kinda useless i know XD)
    so that is exactly i want for now , change the read only check to uncheck (and it is not happening)
  7. djsfantasi
    Apr 11, 2010
    2,905
    878
    What is a "carpet"?
  8. m4lyg0s
    Apr 17, 2014
    11
    file, folder haha sry
