CM for wind turbines
Discussion in 'Homework Help' started by hackers99, May 10, 2010.
  1. hackers99
    Nov 18, 2009
    36
    Why they prefer synchronous(PM) generators instead of DFIG (Double fed induction generator) in condition monitoring for wind turbine generators? plz can anyone tell me...
  2. retched
    Dec 5, 2009
    5,201
    313
    The PM doesn't require additional excitation voltage for power generation.
    You dont want to use the power you are generating to generate the power.
  3. hackers99
    Nov 18, 2009
    36
    Actually why condition monitoring has to be done on wind turbines what is the primary reason?
  4. retched
    Dec 5, 2009
    5,201
    313
    Usually to be sure something can be done in case of winds that are too fast for the turbine. You can load down the generator to slow the blades to keep damage from off balance blades and bearings that cannot handle the RPMs.
    This link may offer some insight:
    http://www.plant-maintenance.com/articles/ConMon21stCentury.shtml
  5. hackers99
    Nov 18, 2009
    36
    please can anyone help me i'm doing a project
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  7. hackers99
    Nov 18, 2009
    36
    what are the main differences between DFIG and syncronous generator?
  8. hackers99
    Nov 18, 2009
    36
    can any one tell me why condition monitoring is done on wind turbine blades is there any specific technique is used?
