Clone a sata hd to a larger one
Discussion in 'Computing and Networks' started by Dodgydave, Jul 2, 2013.
  1. Dodgydave
    Thread Starter AAC Fanatic!
    Jun 22, 2012
    5,141
    767
    Ok having searched Google/ Youtube and got confused over different programmes,
    i have a laptop with a 160g hd, and running win7 32bit, i want to put everything onto a 500g hd sata, and install it in the laptop and hey presto it boots up and runs as normal with the bigger hd. What software do i need to download with the easiest method ?
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    Sorted it , i used Macrium Reflect
    Thanks for the no replies.....
  3. shortbus
    Sep 30, 2009
    4,088
    1,670
    Thanks for starting a double post. You've been here long enough to know better.:confused::p:)
    tshuck likes this.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    You have plenty of replies on the first thread you have on this topic.
  5. egobrainz
    Mar 8, 2010
    10
    use xxclone.it freeware for personal use.
    clone your system drive to new hdd,(make destination partition first on new hdd)
    then boot from new hdd,if failed to boot,insert windows instalation disc then select start up repair.
    xxclone so perfect,its not fully clone like other tool sector-per-sector and not copy bad sector,plus new cloned partition defragmented free.
