Multiplying can be done with a Phase Locked Loop. http://www.educypedia.be/electronics/pll.htm
In a PLL an oscilator can be compared with a reference.
If you divide the oscillatorfrequency you will get a stabelised frequency that is mutiplied by the division factor.
An other posibility is multiplier stages.
A multiplier stage is a non linear amplifier with a tuned circuit at the multiple of the input.
Multply stage follow for 100 X are 2 X 2 X 5 X 5 X.
But 5 X stages are nor so easy.
Here is some text from a radioamatuer page.
FREQUENCY MULTIPLIER
The oscillator is generally designed to operate on a low frequency, because it is more stable. In order to achieve output on the higher frequencies, it is necessary to employ one or more stage of frequency multiplication. An advantage gained from this arrangement is that by operating the oscillator at a relatively low frequency, it is easier to achieve the necessary frequency stability. A single multiplier stage may produce twice the fundamental frequency (frequency doubler) or three times (tripler) or more. Usually, however, the frequency multiplication in one stage is limited to three. It is undesirable to feed the antenna directly from a multiplier since harmonics, other than the wanted signal, are produced and maybe radiated simultaneously.
sigh... really hard to find that 3.2768MHz xtal... all I got is 3.5xxMHz.. will be using it to clock the EPE LCf meter project... can a 3.5xxMHz xtal be -slowed down- by replacing the 22pF caps with 100p caps??
Sanjay04313,
you are "hijacking" the topic, which is very much frowned upon. If you wish to start a new topic, please do so. However, we generally do not "send" information to a poster; instead replies are made to the thread. You can elect to be notified about additions to your thread by clicking the "subscribe to this thread" button.
