clock signal generator
Discussion in 'Homework Help' started by Tanaka, Feb 27, 2012.
  1. Tanaka
    May 27, 2011
    Which circuit can I use to produce a clock signal. I have suggested an astable multivibrator, but i am not sure if it does the job best
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    You have to provide more information than this: frequency, voltage, current, load.
    Can you tell us your application in more detail?
    Tanaka likes this.
  3. magnet18
    Dec 22, 2010
    1,232
    125
    32.768 kHz crystals usually work well
    32.768 MHz is also an option if you need increased accuracy
    sometimes a 555 works fine
    depends on the application
    Tanaka likes this.
  4. panic mode
    Oct 10, 2011
    1,328
    305
    higher frequency crystals give you better resolution (more pulses per second) but that has no effect on accuracy.
    it is the tolerance and frequency stability that tell accuracy. both parameters are normalized and expressed in PPM (parts per million) so frequency makes no difference.
    for example you can have 20ppm crystal running at 100kHz and another that is 100ppm and running at 10MHz. both can be used to create base for clock but the first one would be more precise (that clock would need fewer adjustments over time).
    Tanaka and magnet18 like this.
