clock pulse oscillator and square wave osc. ?
Discussion in 'General Electronics Chat' started by matbymay, Aug 28, 2009.
  1. matbymay
    Jul 14, 2009
    27
    hi everbody
    are there any differences between clock pulse oscillator and square wave osc. ? i just want to use square wave oscillator and i found DS1087LU-21H+ from maxim. could you check it please it is useful for frequency:16 mhz and amplitude value:2V
    http://datasheets.maxim-ic.com/en/ds/DS1087L.pdf
    thank you for help
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    A clock pulse oscillator is dependent on what your feeding with it. Generally it is a precision oscillator, with a frequency that is more stable than most. It can come out with a square wave, or it may need to be squared up. I suspect this clock signal will need amplified and squared.
    It can be a simple RC oscillator that is very imprecise. Depends on what your doing with it.
    What is your application?
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    That device gives a TTL Level square wave output, but it's a specialist part to give a deliberately varying 'spread spectrum' frequency (it continually shifts by a small amount), as well as a programmable division.
    You would be better off looking at a generic crystal oscillator module like this type of thing:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=X116-ND
    There are many types and sizes, both 5V and 3.3V and readily available in many frequencies.
  4. matbymay
    Jul 14, 2009
    27
    i would like to use for led driver and also mixer to mix two different frequency signal which come from these oscillator
    and the part is (which i have sent datasheet) fixed frequency it gives 16 mhz factory frequency so i dont need to programme it.
    still can i use these oscillator ?
