Clock frequency divider circuit
Discussion in 'Electronics Resources' started by Huzaifa Asif, Mar 22, 2015.
  1. Huzaifa Asif
    Mar 22, 2015
    11
    In order to create a divide-by-two circuit, we only use an inverter that is connected between the output and the input of a flip flop.
    What if we want to create a divide-by-six circuit? Cant we use an inverter for that?
    Regards
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Here's a divide-by-six using an inverter
    absf likes this.
  3. Huzaifa Asif
    Mar 22, 2015
    11
    I am permitted to use only flip flops.
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    A pity you didn't say that in your original post :(. This is clearly a Homework problem. You need to state exactly, in full, the conditions imposed on you.
  5. Huzaifa Asif
    Mar 22, 2015
    11
    Sorry about that however I did mention about flip flops in my question but didn't explicitly stated that we are permitted to use flip flops only.
    That's the only condition that's imposed on me.
  6. absf
    Dec 29, 2010
    1,493
    374
    No kidding.:eek::p I didn't even know it was possible.:cool:
    Allen
  7. absf
    Dec 29, 2010
    1,493
    374
    Look at page 4 of the datasheet attached.
    Allen
  8. Huzaifa Asif
    Mar 22, 2015
    11
    Is D-flip flop different from J-k flip flop? I couldn't understand how it's working.
    Check the third figure where three flip flops are being used with each dividing the clock frequency by its half. I want to make a similar circuit but it's able to divide the clock frequency by six (1/6).
    http://www.electronics-tutorials.ws/counter/count_1.html
  9. absf
    Dec 29, 2010
    1,493
    374
    OK, I use 3x JK flip flop and connected them as T-flip flips as in your link. Then I add a NAND gate to reset the flip flops when it counts to 6 (see circuit attached). So it would be counting from 0 to 5 (i.e. Mod 6).
    Are you able to do it with 3x D-flip flops?
    Allen
  10. Huzaifa Asif
    Mar 22, 2015
    11
    I haven't studied JK flip flops so I can't really understand. I shall be grateful if you can tell me how it works using D-flip flops
  11. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Hint:
    A flip-flop (JK or D or T type) can divide by two.
    6 = 2 + 4.
  12. Huzaifa Asif
    Mar 22, 2015
    11
    Can I 'OR' the output of 1/2 CLK and 1/4 CLK?
  13. Alec_t
    Sep 17, 2013
    5,971
    1,135
    The logic combination you need is 'AND', not 'OR'.
  14. Huzaifa Asif
    Mar 22, 2015
    11
    1/4 * 1/2 gives 1/8 doesn't it?
  15. Alec_t
    Sep 17, 2013
    5,971
    1,135
    In algebra yes; but simply ANDing the outputs of two cascaded flip-flops will give a pulse period 1/4 the input clock pulse period, with a 1:3 mark/space ratio . You need AND logic to detect a count of 6 and then immediately reset the count to zero.
    absf likes this.
