Clock fail detection circuit
Discussion in 'Homework Help' started by ashu123, May 30, 2015.
  1. ashu123
    May 30, 2015
    5
    Can anybody help me design a clock fail detection cicuits without using delay lines.
    I came across the attached circuit which can detect the clock failure of a high frequency clock used as clock1 with the help of a good low frequency clock named clock2.
    My doubt is whether i can detect the failure of the low frequency clock with the help of a good high frequency clock?
    I have attached waveform of the below circuit and my requirement is the reverse.
    Pls help
      File size:
      72.8 KB
      8
      File size:
      39.3 KB
      8
  2. JoeJester
    Apr 26, 2005
    3,392
    1,211
    are you constrained in any manner on your design?
    If you are not, search for Application Note 170 from Phillips Semiconductors. The 555 timer can be a missing pulse detector.
  3. ashu123
    May 30, 2015
    5
    I am planning to use this along with adpll. So my input frequency(clock1) can vary between 61khz to 43Mhz and clock2 is 250mhz.
    Also i dont want to use a frequency divider to divide the 250mhz because to match with my input i may need large dividers.
  4. ashu123
    May 30, 2015
    5
    Also i dont want to use a frequency divider to divide the 250mhz because to match with my input i may need large dividers. I need to code the design in verilog hdl
  5. JoeJester
    Apr 26, 2005
    3,392
    1,211
    61 kHz through 43 MHz and clock 2 at 250 milliHertz?
  6. ashu123
    May 30, 2015
    5
    61Khz to 43Mhz and 250Mhz
  7. JoeJester
    Apr 26, 2005
    3,392
    1,211
    If your planning on using TTL devices, you know 41 MHz is outside their operating range ... and so is 250 MHz.
  8. ashu123
    May 30, 2015
    5
    I want to code such a circuit in verilog hdl and simulate it. I have attached a similar circuit in thread 1
