clock doesnt seem to work I2C dspic30f4011
Discussion in 'Embedded Systems and Microcontrollers' started by xluzx, Oct 31, 2013.
  1. xluzx
    Oct 31, 2013
    So im trying to use i2c to get some data from a mpu6050, but whit the code that im using for some reason the clock does not work. on the osciloscope the scl line seems to be 1 all the time, and from diferent tests it seems that the pic stops waiting for clock signals.
    Code ( (Unknown Language)):
    1.
    2. #include <libpic30.h>
    3. #include <timer.h>
    4. #include <stdlib.h>
    5. #include <stdio.h>
    6. #include <stdlib.h>
    7. #include <p30F4011.h>
    8. #include <i2c.h>
    9. #include <uart.h>
    10.
    11. #define FCY     29491
    12.
    13. //Configuration bits
    14. _FOSC(CSW_FSCM_OFF & XT_PLL16);  //oscilator
    15. //_FWDT(WDT_ON & WDTPSA_512 & WDTPSB_16);  //watchdog timer (interval of ~ 16s)
    16. _FWDT(WDT_OFF);
    17.
    18. char RXbuffer[200];    //buffer used to store characters from serial port
    19. int str_pos = 0;     //position in the RXbuffer
    20.
    21. int main() {
    22.   unsigned int config2, config1;
    23.   unsigned char *wrptr;
    24.   unsigned char tx_data[] = {'M','I','C','R','O','C','H','I','P','\0'};
    25.   unsigned int UMODEvalue, U2STAvalue; //auxiliary UART config variables
    26.
    27.   //Configures every PORTB pin as digital I/Os (wont be using analog inputs for now)
    28.     ADPCFG = 0xFFFF;
    29.
    30.   /* Serial port config */
    31.     UMODEvalue = UART_EN & UART_IDLE_CON & UART_NO_PAR_8BIT; //activates the uart in continuos mode (no sleep) and 8bit no parity mode
    32.     U2STAvalue = UART_INT_TX & UART_TX_ENABLE & UART_INT_RX_CHAR & UART_RX_TX; //activates interrupt of pin Tx + enables Tx + enable Rx interrupt for every char
    33.      OpenUART2 (UMODEvalue, U2STAvalue, 15); //configures and activates UART2 at 115000 bps
    34.     U2STAbits.URXISEL = 1;
    35.     _U2RXIE = 1;                             //0-Interruption off, 1-Interruption on
    36.     U2MODEbits.LPBACK = 0;                     //disables hardware loopback on UART2. Enable only for tests
    37.
    38.     __C30_UART = 2;                         //define UART2 as predefined for use with stdio library, printf etc
    39.
    40.   TRISFbits.TRISF2=1;
    41.   TRISFbits.TRISF3=1;
    42.
    43.   wrptr = tx_data;
    44.   /* Baud rate is set for 100 kHz */
    45.   config2 = 0xB5;
    46.   /* Configure I2C for 7 bit address mode */
    47.   config1 = (I2C_ON & I2C_IDLE_CON & I2C_CLK_HLD &
    48.              I2C_IPMI_DIS & I2C_7BIT_ADD &
    49.              I2C_SLW_DIS & I2C_SM_DIS &
    50.              I2C_GCALL_DIS & I2C_STR_DIS &
    51.              I2C_NACK & I2C_ACK_DIS & I2C_RCV_DIS &
    52.              I2C_STOP_DIS & I2C_RESTART_DIS &
    53.              I2C_START_DIS);
    54.
    55.   printf("\n\rconfig1=%x config2=%x\n",config1,config2);
    56.
    57.   OpenI2C(config1,config2);
    58.   //ConfigIntI2C(MI2C_INT_OFF & MI2C_INT_PRI_1 & SI2C_INT_ON & SI2C_INT_PRI_1);
    59.
    60.   while(1){
    61.   IdleI2C();
    62.   StartI2C();
    63.   // Wait till Start sequence is completed
    64.   while(I2CCONbits.SEN);
    65.
    66.   // Clear interrupt flag
    67.   IFS0bits.MI2CIF = 0;
    68.   // Write Slave address and set master for transmission
    69.   MasterWriteI2C(0xE);
    70.   // Wait till address is transmitted
    71.   while(I2CSTATbits.TBF);  // 8 clock cycles
    72.   while(!IFS0bits.MI2CIF); // Wait for 9th clock cycle
    73.
    74.   IFS0bits.MI2CIF = 0;     // Clear interrupt flag
    75.   while(I2CSTATbits.ACKSTAT);
    76.   // Transmit string of data
    77.   MasterputsI2C(wrptr);
    78.
    79.   StopI2C();
    80.   // Wait till stop sequence is completed
    81.   while(I2CCONbits.PEN);
    82.   CloseI2C();
    83. }
    84.   return 0;
    85. }
    86.
    ty in advance for any help.
  2. Danm1
    Member
    Jul 19, 2010
    55
    7
    make sure your I2C interrupt is configured.
