I have to generate 3 clocks - M, CL1 and CL2 from a 50MHz clock, of frequencies 81.3 Hz, 6.5 KHz and 1.5625 MHz respectively. I have come up with the following VHDL code, but when I create a test bench waveform it shows that the code is not working, and all three remain at logic '0' after the initial reset, before which they appear to be uninitialised. Is my code incorrect (see below) or am I making a mistake creating my test bench waveform?
Guidance is very much appreciated.
Rich (BB code):
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all ;
entity signal_generator is port (
system_clk : in std_logic ; -- 50 Mhz
rst : in std_logic; -- pushbutton rst (?)
m, cl1, cl2 : out std_logic); -- signals to be generated
end signal_generator;
architecture behaviour of signal_generator is
signal cl2_count : std_logic_vector(5 downto 0) ;
signal cl1_count : std_logic_vector(7 downto 0) ;
signal m_count : std_logic_vector(7 downto 0) ;
signal cl2_en : std_logic ;
signal cl1_en : std_logic ;
signal m_en : std_logic ;
begin
-- generates a 1.5625 Mhz signal from a 50 Mhz signal
process (system_clk, rst,cl2_en)
begin
if rising_edge(system_clk) then
if rst = '1' then -- pushbutton
cl2_count <= (others => '0') ;
cl2_en <= '0' ;
else cl2_count <= cl2_count + 1 ;
if cl2_count = "11111" then -- count upto 32
cl2_en <= '1' ;
else
cl2_en <= '0' ;
end if ;
end if ;
cl2 <= cl2_en;
end if;
end process ;
-- generates a 6.510 kHz signal from a 1.5625 Mhz signal
process (system_clk, rst, cl1_en)
begin
if system_clk'event and system_clk = '1' then
if rst = '1' then
cl1_count <= (others => '0') ;
cl1_en <= '0' ;
else
cl1_count <= cl1_count + 1 ;
if cl1_count = "11110000" then -- count up till 240
cl1_en <= '1' ;
else
cl1_en <= '0' ;
end if;
end if ;
cl1 <= cl1_en;
end if;
end process ;
--generates a 81.38 Hz signal from a 6.510 kHz signal
process (system_clk, rst, m_en)
begin
if rst = '1' then
m_count <= (others => '0') ;
m_en <= '0' ;
m<= m_en;
else
m_count <= m_count + 1 ;
if m_count = "1010000" then
m_en <= '1' ;
else
m_en <= '0' ;
end if ;
end if;
m <= m_en ;
end if ;
end process ;
end behaviour ;
