clipper circuits
Discussion in 'General Electronics Chat' started by isha, Oct 28, 2005.
  1. isha
    Thread Starter Active Member
    Sep 16, 2005
    36
    where we use clipper & clamper circuits
    OR what are applications of clipper & clamper circuits in daily life
    [clipper is use in rectification to convert ac to dc]
  2. haditya
    Jan 19, 2004
    220
    clampers are used to change the level of a signal usually at the ends of a transmission /reception..thats one application i m aware off...there cud be several more
  3. richbrune
    Oct 28, 2005
    106
    I'm pretty sure you want to look into a power supply cookbook of some type. You'll see these terms used when designing switching power supplies, and when designing the initial stages of low voltage electronics where levels of voltage must be controlled to avoid damage to components, and to provide stable operations.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Pulse height analysers use clipping to eliminate pulses from photomultiplier tubes in order to discriminate against particles with energies different from the ones of interest.
    FM receivers clip the signal to keep out noise, as the frequency received carries the information.
  5. Gorgon
    Aug 14, 2005
    113
    You use clampers & clippers every time you turn on your television set.
    TOK ;)
  6. isha
    Sep 16, 2005
    36
    beenthere
    can you explain?
    whats pulse height analysis & photo-multiplier tubes?
  7. shoaibshapuri
    Sep 30, 2006
    Clippers are used in many electronic circuits .
    i know only two applications and hope to know more from u.so please email me
    The two applications which i know are
    1.clippers are used in rectification procees ,that is to convert ac to dc.
    2.they are used in wave shaping.
  8. Vishg14
    Apr 16, 2009
    Clipper circuits is basically a recitifier circuit(Rectifiers). We use it in wave shaping,TV.
    clamper circuit is used in voltage multipliers,adding dc voltage.
    The best application of clamper circuit is camera:
    In camera a flash is generated, which requires high amount of voltage. That high voltage is generated using a clamping circuit.
