I have been trying to create a high frequency biased clipper circuit using a schottky diode. I am using the same circuit as
, but with only single sided clipping.
The problem I am facing is that the DC power supply I use to bias the diode draws a very high current which limits the bias voltage, Therefore I cannot set correct bias voltage to set the clipping limit.
Any help/suggestions would be great
