clipper and clamper circuits
Discussion in 'General Electronics Chat' started by Nirnay Chakraborty, Nov 2, 2010.
  1. Nirnay Chakraborty
    Nov 2, 2010
    How the clipper and clamper circuits work on a dc output signal.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Clipper and clamper circuits are described in Chapter III of our E-book:
    http://www.allaboutcircuits.com/vol_3/chpt_3/index.html
    If you feed them a DC level that is within the clipping/clamping range, it will have virtually no effect on the output signal. However, if the input DC level goes outside the clamp/clip range, the output won't go past the limits.
  3. Kermit2
    Feb 5, 2010
    3,852
    968
    We make a small voltmeter for Schlumberger that is capable of resolving millivolt levels of DC and AC, yet can be directly plugged in to a 120VAC wall socket and not be damaged.
    We use two high wattage, back to back, 12 volt zener diodes, to "clamp" the input to the meter at 12 volts max. Some wire wound resistors dissipate the excess power and the meter survives.
