I need to limit a signal to the following range: [-0.25 V, 0.25 V]. This signal is comming from a shunt resistor in series with a load with variable impedance on a 220 V power grid.
The project contemplates loads up to 1 A peak, but I can't guarantee this restriction will be obeyed all the time. But I need to guarantee the resulting voltage don't exceed the specified range.
To give a small guarantee, I'm using a shunt whose equivalent resistence is approximately 0.235 Ω, which generates a voltage slightly below the limit when 1 A is consumed.
I cannot use normal diodes because its forward voltage is too high. I've tried to use two low forward voltage Schottky diodes (BAT46), but didn't worked perfectly in my simulations.
Here's my current schematic:
OBS: the thing that looks like a voltage source on the right side is a voltmeter, you can ignore it.
Where:
The result:
Where both signals have a scale of 0.1 V/div.
As you can see, the signal is being clipped, but in a threshold above the allowed [-0.25 V, 0.25 V].
How can I modify this circuit to achieve the correct threshold? I'm focusing primarily on solutions involving components easily obtainable (even if the circuit design change completely, I was thinking about use some op amps), because I live in Brazil and here there is a very low supply of components. So if I need to buy something "different", I have to import and it will take weeks to arrive.
Where:
- R_IC is the IC's input pin impedance, according to its datasheet.
- R_LOAD is the already mencioned variable load. In most circumstances, it will consume less than 1 A peak, in another words, its "average" impedance will always be above 311 Ω. But I'm trying to avoid the range of the input pin to be exceeded in possible peaks (when the load is connected, for example).
The result:
