Hello.
I have a sliding gate operator,C.E.M brand,as in the attached photo.
Last week i change the 4A fuse in the PCB,since it burned out while there was a
voltage surge.
After changing the fuse,the sliding gate operator works fine.
When i press the remote control button-the gate is opened and closed smooth and fine.
But while the gate is in moving(either in close motion or in open motion),the PCB has
a constant clicking sound(like a relay sound)as long as the gate is in moving state.
This was the first time that i noticed the clicking sound,since the PCB was without its cover.
And i was checking the gate movement,while the operator was dismantled.(without its cover).
After i installed back its cover,the clicking sound was less noticeable.
So,i don't know if this sound indicates a proper and normal operation of the PCB
(which i,just,didn't hear,while it was covered),
or this indicates a fail PCB?
Thanks in advance.
voltage surge.
Thanks in advance.
