Good Lord! Couldn't you post a bigger picture?Hi, so i have built the circuit
The problem i am now having is how to test it properly.
The push switch is set up to be normally off, using 3A.
How do i check if it works?
I think i should use an oscilloscope at the 2200 ohm resistor(replaced the initial 200ohm) to see if the current increases from the normal 0.01 to 0.4A. (the purple wire connects my circuit to the oscilloscope)
My LED didnt turn on or off. I expect my LED to start off on, the instant i push the switch it should turn off and stay off till i reset the circuit.
I have yet to include my reset button. what type of reset button should i use?
if anything is unclear and annotations are needed please let me know.
I don't have patience for tracing a breadboard that is way bigger than my computer screen (which is big). Please post a smaller picture, both physically and in megabytes. You can post jpeg pictures. You don't need to convert them to PDF.
Are those resistors next to the LM393 shorted? How do you know that's a 393? And where is the orientation notch?
For reset, just use a NO PB switch from the reset pin to +10V, connect a 10k resistor from the reset pin to GND.
BTW, if you don't have that resistor installed, the FF may not work. Leaving CMOS inputs floating is a no-no. Even on the unused section, unused inputs must be connected to GND.
It looks like your CD4013 wiring is totally screwed up. You have no power or ground connected (see the datasheet), it looks like pin 8 goes to pin 9 (why?), and I don't know what else. Post my schematic with the pin numbers added, and we'll try to get it figured out.
