yes i did look at the circuit and it was helpfulDid you even look at the circuit I showed in post #18 ?
Your circuit has zero threshold (it will switch when current≈0), and, if it DID have a threshold, would need hysteresis to prevent oscillations when current is at threshold.You must in the future give your design constraints in the first couple of posts !. This is the first time saying "I am REQUIRED to use a Schmitt trigger"! If you had said that in the beginning you would have saved a lot of time, yours and mine!
Here's around 23,700 answers to the question - https://www.google.com/search?q=sch...87,d.aWc&fp=49428f98d57244d1&biw=1010&bih=624
If I had a clear idea of what you are trying to do, I would help design a circuit for you. You have a communication problem. I know you are trying to make a circuit breaker, but I don't know what the circuit looks like that needs to be protected. If you would post the unprotected circuit, and some idea of what might cause a fault, instead of always including your attempt at a solution, it might help.can't see any examples for dual supply
only single please help
yes it is my work but i am on the forum to get help
i include my attempt at a solution to show that i am not just sitting on my hands.If I had a clear idea of what you are trying to do, I would help design a circuit for you. You have a communication problem. I know you are trying to make a circuit breaker, but I don't know what the circuit looks like that needs to be protected. If you would post the unprotected circuit, and some idea of what might cause a fault, instead of always including your attempt at a solution, it might help.
That's pretty clear. What causes the switch to close?i include my attempt at a solution to show that i am not just sitting on my hands.
i am not attempting to protect a circuit. I am simply trying to protect the load.
The load is a 200 ohm resistor in parallel with a 5 ohm resistor.
what causes the fault is when the the mechanical switch in series with this 5 ohm resistor closes.
the total load resistance becomes 4.87...
my supply is 20V, therefore total current when switch closes is 4.1A VS when the switch is open 0.1A
4.1 is the fault current.
I really hope this is clear. Please remember, the breaker is to simply protect my resistors. Thats is all.
thank you.
i make the switch close.That's pretty clear. What causes the switch to close?
yes it should interrupt all of the current.And should the circuit breaker leave the current flowing through the 200Ω resistor, should it interrupt ALL the current?
You are saying:yes it should interrupt all of the current.
and yes it should leave the current flowing through the 200Ω
Those two statements are not consistent. Leaving current flowing through the 200Ω resistor is NOT interrupting all the current. Can you see why your posts are so confusing?yes it should interrupt all of the current.
So our work is done?i actually got it to work on simulation exactly how i wanted it to, by replacing my N channel mosfet with a p channel mosfet. I have no idea why it works with a P channel mosfet and not an N channel mosfet.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Aaron Carman
