Cleaning up waveform to generate 50% duty cycle
Discussion in 'The Projects Forum' started by robby991, Sep 10, 2010.
  1. robby991
    Thread Starter Active Member
    Dec 17, 2007
    79
    Hi everyone. I have a frequency which I need to convert to 50% duty cycle square pulses. The output is from a frequency divider (d-Flip Flops), so the duty cycle should be 50% but it is not. Is there anyway I can help clean this up? The frequency should be oscillating which it is, however it should keeo the 50% duty cycle. It is oscillating however without 50%. The frequency is in the kilohertz range.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The output from a frequency divider has to be 50% duty cycle, or are you dividing by some factor other than 2?
    That said, if the frequency changes, so does the interval between pulses. If the frequency is held constant, does the displayed duty cycle hold at 50%?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Can you post the schematic of what you have upto now?
    Bertus
  4. robby991
    Dec 17, 2007
    79
    It is going through a divide by 4 frequency divider with d-Flip Flops. The input frequency is also not 50%. The input frequency comes from a current to frequency converter. The current is not constant, it varies, so The frequency will not be conatsnt. However wouldn't the pulses still be 50%?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    First, you need to run your input through a Schmitt-trigger gate to clean it up. A 74HC14, a 4093 or 40106 are a few examples.
    You could also use cascaded 74VHCU04's to amplify the signal. It's a very useful technique. See the attached.
  6. Norfindel
    Mar 6, 2008
    235
    9
    If the frequency varies all the time, how can the duty cycle be 50%? If the flip-flops change state on the rising edge, and the time between rising edges isn't the same every time, the duty cycle won't be 50%.
  7. robby991
    Dec 17, 2007
    79
    What I am saying is that my input current is proportional to the output frequency I am getting, which should be 50%. So if my input current is varying, the frequency would vary proportionally, and each pulse period should remain 50% duty. Is this a correct assumption?
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Again, can you post a schematic?
    So we can see what current to frequency converter you use?
    Perhaps a link to the datasheet will also give the info.
    Bertus
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Only correct for a period in which the frequency remains constant. Why is it so important to maintain a 50% duty cycle as the frequency is changing?
