Cleaning PCB pads and contacts with alcohol
Discussion in 'General Electronics Chat' started by Dritech, Jul 21, 2016.
  1. Dritech
    Sep 21, 2011
    756
    5
    Where I used to work, they used to clean PCB pads and pogo pins with alcohol wipes (70%).
    Is it fine to clean with such a product since it is not 100% alcohol?
    If no, what damage can be done? can it contribute to increase in resistance when applied to the pogo pins?
  2. benta
    Member
    Dec 7, 2015
    101
    24
    Don't see a problem using these, though it would probably be significantly more cost-effective buying isopropyl alcohol and tissues or q-tips from commercial sources.
  3. SLK001
    Nov 29, 2011
    849
    242
    Remember that when the 70% alcohol evaporates, you have water left on the surface. If the solution gets into the pogo pin, the water could damage the spring (depending on its construction). 100% is definitely the best to use, but given that, I use 91% on all of my electronic cleaning needs. If the wipes are just used to clean the surfaces of the pogo pins and the pcb pad, even if water is left on the surfaces, no increase in resistance will be seen, since the pogo pin should bite into the pcb pad when activated (I'm assuming a castellated or chisel point pin on the pogo).
    Dritech likes this.
  4. mcgyvr
    Oct 15, 2009
    4,787
    974
    Yep.. IPA is commonly used as an economical flux remover on soldered circuit board assemblies..
    Nothing wrong with using it at all.. As stated a higher percentage will simply have less water (91%,etc...)
  5. k7elp60
    Nov 4, 2008
    478
    69
    I have been using anhydrous-pure isopropyl alcohol for a long time, it works very well. The part# is GC electronics 10-1507-A.
