CLC peripheral on PIC16LF1503
Discussion in 'Embedded Systems and Microcontrollers' started by selfbg, Apr 18, 2012.
  1. selfbg
    Jun 11, 2010
    23
    I need some help with the new CLC peripherial. I'm making some kind of router (repeater). The signal on CLC1IN1 is repeated to CLC1. No matter what I do, I can't get it right. I'm using the CLC design tool by Microchip, but still - epic fail. :) I'm looking for example that really WORKS. :rolleyes:
    Here is my code:
    Code ( (Unknown Language)):
    1.
    2. .......
    3. static char Init_CLC(){
    4. APFCONbits.CLC1SEL = 1; //CLC1 on RC5
    5. CLC1CONbits.LC1EN = 0; //Disable CLC1
    6. ANSELA = 0;
    7. ANSELC = 0; //All pins digital
    8. TRISAbits.TRISA5 = 1; //RA5 - Input - CLC1IN1
    9. TRISCbits.TRISC5 = 0; //RC5 - Output - CLC1
    10. //Configuration bits from CLC designer Tool
    11. CLC1GLS0 = 0x02;
    12. CLC1GLS1 = 0x00;
    13. CLC1GLS2 = 0x00;
    14. CLC1GLS3 = 0x00;
    15. CLC1SEL0 = 0x01;
    16. CLC1SEL1 = 0x00;
    17. CLC1POL  = 0x02;
    18. CLC1CON  = 0xC0;
    19. }
    20. .........
    21.
    22.
    Thank in advise for the help :)
  2. MMcLaren
    Feb 14, 2010
    759
    116
    How about feeding gate 1 and gate 2 with that signal and getting rid of the NOT output on gate 2?
  3. selfbg
    Jun 11, 2010
    23
    I've tried all possible combinations but still no good. The one that I use is from Microchip's designer guide PDF, so I assume that it works. :) Maybe the problem is with input gates. When I change the output polarity the CLC1 pin set.
