Class D Amplifiers!!
Discussion in 'General Electronics Chat' started by tck1911, Nov 13, 2012.
  1. tck1911
    Nov 12, 2012
    5
    Could someone tell me the reason for using a Low Pass Filter in a Class D Power Amplifier?
    Also, what sort of a Low Pass Filter (Fisrt order, second order, active, passive) should be used when designing a Class D amp?
    Thanks!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The filter type isn't that important, basically Class D uses a form of PWM, and needs the high frequency removed, which is the reason for the filter.
    Here is a article I wrote for the AAC book...
    Pulse Width Modulation
    My blog...
    Bill's Index
    A very long while back I helped a user design one using a M-Derived filter (low pass). They are a stone cold dog to tune though.
    tck1911 likes this.
  3. MrChips
    Oct 2, 2009
    12,648
    3,458
    The output from a Class D amplifier switches voltages on and off, i.e. it is a pulse-width modulated (PWM) signal. You don't want to feed this directly into the loudspeaker. This high frequency signal must be smoothed out using a Low Pass Filter (LPF).
    It makes no sense using an active filter because that would require a linear power amplifier, defeating the whole purpose of a Class D amplifier.
    A passive filter using an inductor and a capacitor would give you a second order filter.
    tck1911 likes this.
