class d amp mosfet heating
Discussion in 'The Projects Forum' started by franticAAC, Mar 25, 2015.
  1. franticAAC
    Jun 25, 2012
    28
    i'm designing and realizing on prototypal board the class d amplifier in figure below
    the problem is that the Infineon MOSFETS become too hot beyond the calculations that I made, also without load and with lower voltage than i need. Also they present 100ns of miller plateau at which the measured current on high side mosfet drain is of any amperes.
    I test many mosfets and they all have the same problem maybe less pronounced.
    The only one that doesn't have that kind of dissipation issue is International Rectifier mosfet in figure.
    What do you think? Is it a bad driving or parasitic components of other mosfets?
    I'm looking for a mosfet with lower Rds in order to increase output power...
    Could you help me?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
  3. franticAAC
    Jun 25, 2012
    28
    The switching rate is 50KHz.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    What sort of heatsinking for the FETs do you have?
  5. franticAAC
    Jun 25, 2012
    28
    A D2pack heatsink Rth=15°C/W but now i'm doing test without it mounted
  6. crutschow
    Mar 14, 2008
    13,478
    3,365
    How much deadtime do you have between the switching of the upper MOSFET and the lower MOSFET?
  7. franticAAC
    Jun 25, 2012
    28
    i tried different dead times from 20ns to 100ns but nothing changes
  8. crutschow
    Mar 14, 2008
    13,478
    3,365
    How do you generate the dead (non-overlap) time?
  9. franticAAC
    Jun 25, 2012
    28
    pwm signals are generated by fpga and are connect to adum input pins
  10. crutschow
    Mar 14, 2008
    13,478
    3,365
    I'm trying to determine what the two signals look like that are driving the top and bottom MOSFETs in the bridge.
    Where does the deadtime occur?
  11. franticAAC
    Jun 25, 2012
    28
    Could you explain me better?
  12. crutschow
    Mar 14, 2008
    13,478
    3,365
    Okay. I'm trying to determine if the deadtime delays are being done correctly, i.e. does the top transistor always turn OFF before the bottom transistor turns ON, and does the bottom transistor always turn OFF before the top transistor turns ON.
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    Especially considering the FET turn off delay as shown in the sim I linked to...
