Class B Audio Amplifier
Discussion in 'The Projects Forum' started by BigglesPiP, Apr 1, 2006.
  1. BigglesPiP
    Apr 1, 2006
    I built the circuit from this website in MultiSim
    I'm going to:
    Measure the voltage theat my mp3 puts out.
    Measure the current when it's playing into my car stereo with the cassette tape adaptor. At normal voltage (FM radio @ good volume) on the stereo and full on the player (too quiet).
    And through V=IR and P=I(squared)R calculate the power (Whatts) that it is right now and use that in the simulation
    This should give me a good guide of how much amplification I'll get with various values of resistors etc. THen I can confidentely make 2 of them (stereo sound) on soldered breadboard.
    Also this will be the 1st circuit I've ever soldered to breadboard.
    Please do poke holes in my plans,
    Cheers,
    Bracken
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Is this for in the car..??
    Some things to keep in mind, most cars are only 12 volt and don't possess a "dual 12 volt battery with centre tap at earth" system.
    You can also Quadruple the power output into a given load by bridging 2 amplifiers into that single load. Another way to increase power is to use an inverter to step up the 12 volts into a higher voltage split rail supply..(this is how most modern high power amps work).
    I might also check for crossover distortion on that design, as it is normal to fit emitter resistors on the output.
    And whats the deal with the linear pot..? Is it some form of variable negative feedback..?
    The design looks a little unconventional, but without trying it myself, I cant offer any further insights.
  3. BigglesPiP
    Apr 1, 2006
    I'm going to switch to 2 PP3's for power.
    I just measured the Resistancwe of the cassatte adaptor in use to be 150 Ohms
    the linear potentiometer is the volume controll.
    I'm not sure about the crossover distortion but the page i got it from on this website said it can be used as is for an amplifier.
    Anyone know the mean pk-pk voltage a portable audio player puts out?
  4. mozikluv
    Jan 22, 2004
    1,437
    hi,
    the term you use "portable audio player" is quite vague. pls. be specific so we can give a an educated guess or a specific answer.
    moz
  5. n9352527
    Oct 14, 2005
    1,198
    It wouldn't last long with 2 PP3s.
  6. BigglesPiP
    Apr 1, 2006
    I've found out that the headphone soket on a Mac G4 is about 1.4v Pk-Pk. So I'm running my simulations based on that.
    I only need the volume to nearly double.
    But with the volume quadrupling I'm only drawing about 150mA from each PP3 cell.
    Surely that must last long enough.
  7. n9352527
    Oct 14, 2005
    1,198
    Duracell Plus is quoted at 550mAh and I would think that this is measured under less than 150mAh current drain. Anyway, simple calculation and ignoring the effect of high current drain would result in around 3.5 hours of battery life.
    Btw, when you said doubling or quadrupling the volume, did you actually refer to the Vpp/power of the signal or the actual dB of the sound? Of course you have to realise that relationship between Vpp/power and sound loudness is not linear.
