The 1N914 and 1N4148 diodes are a good match to the 2N3904 and 2N3906 transistors to reduce or eliminate crossover distortion. The current in the diodes creates the amount of voltage across them. The current is adjusted by changeing the values of R2 and R4 in Junior's circuit.
Junior, you have the volume control connected backwards so it shorts the output of the generator when it is turned down.
The generator should feed the top terminal of the volume control and the slider should feed the input of the amplifier.
Short together the bases of the output transistors (then the diodes are removed) to see the severe crossover distortion when the transistors operate in class-B.
