The idea of the project is to create a Bluetooth enabled Active loudspeaker.
This is essentially a speaker that you connect to the mains to provide power and the audio signal is received wirelessly via bluetooth.
Im still not 100% sure what you mean here. I understand that one wire is connected to the input of the AMP IC not sure about the other part though,One wire has a capacitor-coupled signal to the input of the amplifier IC and both have grounds that are connected together.
