Hi there!
For a homework project we've been given a class AB amplifier to analyse and solve. The circuit is linked to a Vcc=12V power supply to boost the signal at the npn collecter terminal and to ground at the pnp emitter terminal. However when I model the circuit in LTspice it seems like only the npn transister is contributing to the output while the pnp does nothing at all.
Do I need to connect the pnp to a negative power supply in order for it to work?
