Class A Output Stage
Discussion in 'Homework Help' started by samji, Nov 2, 2009.
  1. samji
    Nov 2, 2009
    Hi all, I'm having trouble to solve an exercise about class A output stage.
    This is my circuit
    I need to calculate the VBB and I have to do it without the beta from the transistor.
    My first idea was using beta with Ic / Ib = Beta and with the value of Rb I should know.
    My second idea is none.. Can you give me some ideia to solve this?
    All I know is :
    I_CQ = Icmax/2
    Icmax-> max collector current
    I think I_CQ will be the current on the transistor ?!?
    V_CEQ = Vcc/2
    And I think V_CEQ will be the voltage between the collector and the emitter.
    Sorry about the english, I'm from Portugal :)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. JoeJester
    Apr 26, 2005
    3,403
    1,227
    What value are you using for Vbb? I see the connection and it gives the illusion that the Rb is connected to ground and not the Vbb source.
    You can infer the maximum collector current as Vcc / Rc since that is the extremes of the collector current.
  4. samji
    Nov 2, 2009
    Thanks for the replies, after all this has to be done in lab by the adjustment of vbb to get the maximum simmetric excursion without distortion.
    that link that you showed me, thanks ;)
