Class A amplifier design help...car audio
Discussion in 'General Electronics Chat' started by chunkmartinez, Oct 20, 2013.
  1. chunkmartinez
    Thread Starter Senior Member
    Jan 6, 2007
    180
    Hello all....I am wanting to learn as much as possible about SMPS circuit design and anything new about audio amplifier design that I can.
    I want to design and build a Pure Class A amplifier for car audio using an smps power supply. Why class A if AB is more efficient and sounds just as good? The novely of it, for fun etc...
    Since class A amplification will create so much heat My goals will be 100w RMS x 2 channels(stereo) at 4 ohms.
    Where to start?
    Should I use an opamp for the pre-amp or design a discreet pre-amplifier? I heard Discreet component class A circuits can be hard to design what do you all think?
    On the SMPS side, I figure I will use the same topology that most car audio amps use, a push-pull, or can I use other topologies? This is where I will learn and see what I can do. What switching frequency would be good to use(how high can I go), any ideas on toroidal cores for the filtering and the transformer, wire guage, types of mosfets to use for the smps, and for the audio side and how many I would need for my target?
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    So, you basically want to design an audio amp so inefficient it will need cooling from a garden hose but build a switching converter to feed it to conserve power?
    Interesting......
    IMHO, it is impossible to hear any difference between a Class A amp and a WELL DESIGNED class AB, but that's just my opinion.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    Push pull is the way to go. SW frequency is as high as possible with acceptable losses in the switching magnetics and FET devices.
    BTW: switchers are like small radio stations. Preventing the EMI from seriously contaminating the sound quality is quite a challenge.
  4. chunkmartinez
    Jan 6, 2007
    180
    I meant using SMPS for the power supply like all amps use. I will Not be converting the output to class D or anything. Like I said the reason I want to go with a class A is for the novelty and the learning experience.
  5. GopherT
    Nov 23, 2012
    6,339
    4,083
    Now that you gave the OP a solution to the cooling problem, I want to see this thing get built!
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    chunkmartinez likes this.
  7. killivolt
    Jan 10, 2010
    432
    351
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    Count me in.
    I like to see how OP can keep a class A @ 200W RMS playing at for than a few hours. I believe OP will need a KW PSU
  9. #12
    Nov 30, 2010
    16,705
    7,358
    Here are 2 ways to do it.
  10. BobTPH
    Jun 5, 2013
    807
    121
    I think it would be cool if your amp could also be used as a toaster.
    Bob
  11. #12
    Nov 30, 2010
    16,705
    7,358
    Too much difficulty keeping nichrome the same resistance as it heats up. This will probably have to settle for being a space heater.
  12. bountyhunter
    Sep 7, 2009
    2,498
    507
    space heater.....
  13. BobTPH
    Jun 5, 2013
    807
    121
    But that is too easy. Maybe build it onto a set of headphones so that it can also be a hair dryer?
    Bob
  14. chunkmartinez
    Jan 6, 2007
    180
    After thinking about it you guys are right. What do you think about a full-range class D amplifier? I'm thinking 150W x 2. Any suggestions about components? Can I use a hip4080 for the H-bridge driver?
  15. GopherT
    Nov 23, 2012
    6,339
    4,083
    Don't be a quitter. Class A can be fun. Old GM (and possibly other) cars used them on their little AM radios (as TO-3 PNP Germanium). Instead of quitting, lower your expectations. Try something in the 5 to 10 watt range. It wont be nearly as fun since a flowing garden hose will not be required for cooling.
  16. chunkmartinez
    Jan 6, 2007
    180
    I have seen some lower power circuits online so I thought about trying them...I will post back when I find one I like.
  17. bountyhunter
    Sep 7, 2009
    2,498
    507
    That's what I told my wife on our second date..... been married 32 years now.;)
    GopherT likes this.
  18. GopherT
    Nov 23, 2012
    6,339
    4,083
    Ha! Thanks!
  19. chunkmartinez
    Jan 6, 2007
    180
    Actually I am leaning towards switching circuits now adays. I am going to try and make a buck converter today to drop my LARGE transformer's 40v supply to 12v. The transformer looks to be able to supply 2kw. I want to use the transformer for repairs etc...
    So....While I am at it, I will need to start delving into switching. I want to either go with a simple 555 timer, comparators, or my tl594 IC I have. So I want to go with a full-range class D.
    Does anyone have an idea on components for a buck converter from 40 to 12V. Since I have a large current ceiling, should I use large wire for current handling? I have 10guage magnet wire...and big shotky diodes.
  20. #12
    Nov 30, 2010
    16,705
    7,358
    Not for 2KW
    I wouldn't even bother to ask the TI simple switcher calculator for a 150 amp supply.
