hai chyadesh, the voltage drop is the potential difference across any two points ,so in parallel loop the 2 points are going to be the same and hence the same voltage across any loop.
current flow is as that of water flow i e when it flows through the same loop or pipe its constant or same ,when it flows through many loops or tubes it gets divided..
