Clap Switch
Discussion in 'The Projects Forum' started by Yadi, May 27, 2012.
  1. Yadi
    May 27, 2012
    Hi Guys
    I am having a problem with my clap switch. I build a clap switch that operates on a single clap and it works perfectly but I want to change it to a double clap on and double clap off and I am having a problem doing that. I want to connected a 7476A IC (dual J-K flip flops with preset and clear function) into my circuit as a 2-bit binary counter but I am just not sure how and where to connect it into my circuit, and I will also need a automatic reset circuit to reset the 2 J-K flip flops after the second clap but I don't know how to build this reset circuit either. Can anyone help me please?
    Would be much appreciated. :)
  2. mcasale
    Member
    Jul 18, 2011
    210
    12
    Interesting problem -- and without a processor, too.
    I recommend you start with a timing diagram that lays out how this thing works. So, I'd suggest adding a clock chip that drives a state machine, which could be some shift registers.
    This is obviously a lot more complicated than a "single clap" switch that just needs to detect one sonic threshold.
  3. absf
    Dec 29, 2010
    1,493
    374
    I came out with a simple 2 stage JK FF that counts the claps and drive the lamp after 2 claps. The problem is that when the power is up, the 2 FF are in undetermined states and 2nd problem is I am not sure the inverter can be replaced with a transistor or not. I havent make this circuit so if you want, you may use it as a reference.:D
    Allen
