clamper using opamp
Discussion in 'The Projects Forum' started by onlyvinod56, Mar 4, 2013.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hello.
    I have a symmetrical triangular wave with specifications mentioned below:
    Vpp = 2v
    freq = 1000Hz. (voltage swings from +1 to -1)
    i need two clamper circuits such that the following requirements should be fulfilled.
    1) Vpp = 2V; same freq.; voltage should swing from +2v to 0v
    2) Vpp = 2V; same freq; voltage swing range +4v to +2v
    I have few 741 opamps and i want to utilize them.
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    Easy to do with the 741. Power it up with a dual power supply (+/-9, or 12 or 15V). Configure as inverting unity gain (output connected to inverting input via 1K resistor, and 1K resistor from inverting input to your signal. Then, arrange a voltage divider that will apply +1V to the non-inverting input. This will invert the triangle wave (won't matter it is symmetrical), and cause the output to vary between +2V and 0V.
    Same circuit as above, but create a voltage divider to apply +1.5V to the non-inverting input. This will cause the output to vary between +4V and +2V.
    onlyvinod56 likes this.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    That will work, IF you make the voltage on the non-inverting input +0.5V.
    If the inversion is not acceptable,there are various ways to do it.
    BTW, these are not clampers, they are level shifters.
  4. onlyvinod56
    Oct 14, 2008
    362
    Thankyou w2aew.
    Does this shifter work for any frequency?
  5. onlyvinod56
    Oct 14, 2008
    362
    Tell me if iam wrong.....
    Inversion can be cancelled here by giving the signal to non inverting terminal.
    Or
    For the same circuit i have to connect a non inverting amp again.
    OK. level shifters. Thankyou RON.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    You can do it with a noninverting circuit, but of course it will be different than that described by w2aew. Or, you can use his circuit (with the change that I mentioned in post #3), but you will have to change the DC offset voltages from positive to negative, and add an inverting unity gain circuit.
  7. onlyvinod56
    Oct 14, 2008
    362
    Here are my simulated results.
  8. onlyvinod56
    Oct 14, 2008
    362
    Ok. I'll simulate it. I'll be back soon.
