hey, thanksHello,
Have a look in the following PDF:
sloa011Understanding Operational Amplifier Specifications.pdf
Bertus
The closed loop gain is controlled by the external components and the open loop gain does not enter into the calculation.What is the relationship between the open-loop gain of an op-amp and the closed-loop gain of an inverting amplifier?
Open loop doesnt enter into what calculation?The closed loop gain is controlled by the external components and the open loop gain does not enter into the calculation.
Suppose Aol=100k, and the feedback ratio is .001. You actual gain would be ≈1% lower than the value calculated from the feedback resistor ratio. Open loop gain can usually be ignored, but you need to be aware that it is finite.The closed loop gain is controlled by the external components and the open loop gain does not enter into the calculation.
"Seldom" is the key word here. This is precisely why I saidThat is true, but we seldom have a closed loop gain that is closer to the open loop gain than say four orders of magnitude.
by Jake Hertz
by Jake Hertz
by Jeff Child
by Duane Benson
