ckt modification
Discussion in 'Homework Help' started by maanas.adi, Jul 4, 2013.
  1. maanas.adi
    Nov 3, 2011
    hi all
    i have been given a ckt to minimize the components required. i am attaching the ckt as pdf.
    working:
    the ckt is for operating a small dc motor. when sw1 is pressed it starts moving in left direction. after reaching the extreme left position, we get indication through No/NC contacts. the motor cannot be stopped in between. when in left position then only switch 2 will work.
    i cannot use digital pulse based h-bridge or microcontroller. also another switch might be required to stop the motor in between and then change the direction.
    thanks in advance
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    So.... what have YOU done to try to solve YOUR homework problem? You need to show an honest attempt that will serve as the starting point for a discussion.
