CKT help
Discussion in 'The Projects Forum' started by chacha1234, Oct 21, 2006.
  1. chacha1234
    Oct 21, 2006
    My Dear Friends,
    Its a simple circuit (but its beyond my head!!! hehe!)
    Please see the diagram:
    Here through AB supply is given. C is a capacitor for charging and then discharging at the load end.
    e-S/W is an electronic switch (I need the circuit for this switch) which when pressed, discharge the energy from the capacitor (just like a triggering action), but the electronic switch MUST NOT consume any power from the circuit, so that the amount of chraged energy equals the amount of discharging energy!
    Requirement: (for this whole circuit)
    1) about 10-20J energy;
    2) Voltage ~ 200V;
    3) Current ~ 5A.
    ACTUALLY WHAT NEED IS:
    I need to know the exact amount of energy charged to the capacitor and the exact amount of energy discharged at the load end.
    I need your HELP, friends ! Can you suggest any electronic switch circuit for the above?
    If u need any data may post here OR pm me.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Disappointment is a fact of life. Everything consumes power. However, a nice big Hexfet like an IRF520 is cheap and will handle the voltage and current requirement. It will need a heat sink for any duty cycle above a few percent. Just put 10 volts on the gate to turn it on (be a good idea to get the spec sheet).
