ciruit Analysis
Discussion in 'Homework Help' started by bk123, Nov 24, 2014.
  1. bk123
    Nov 24, 2014
    5
    If a 10 ohm resistance is connected to an a.c voltage of 100 sin(314t + 30deg), the power dissipated is?
    kindly reply
  2. bk123
    Nov 24, 2014
    5
    In an RL circuit the resistance and reactance are 4 ohms each. in this circuit how the voltage and current will be i.e., which one lags/leads the other one and by what degree ?
    kindly answer please
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    We are not an answering service.
    Show us what you have done to solve the questions and we can see if corrections are needed.
    Bertus
  4. bk123
    Nov 24, 2014
    5
    In an RLC series circuit R=5 Ω, Xl= 10Ω, Xc=15Ω fed from V= 100 sin (314t). RMS current will be?
    kindly reply
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Any bets on when the steam will start coming out of Bertus' ears?
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Hi bk123,
    Welcome to the forum. We will not spoon feed you answers to questions. If you show us what you have done to solve the problem we can help you learn to solve the problems on your own. Please say you understand the content of my post.
  7. WBahn
    Mar 31, 2012
    18,079
    4,917
    The power dissipated is something.
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    Yes, one will lead or lag the other by some degree.
  9. WBahn
    Mar 31, 2012
    18,079
    4,917
    The RMS current will be something.
    I figure if you only want answers, then I will oblige. But I'm only going to put as much effort into my answers as you have put into showing YOUR efforts to solve YOUR homework.
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    If I gave you an answer, but it was wrong; would you be able to catch my mistake?
