what should i do to get a parallelogram shape?You probably want to generate a waveform that shows a circle on your oscilloscope - http://en.wikipedia.org/wiki/Lissajous_curve
u mean we cannot generate a parallelogram using a function generator?There is no rectangular shape possible with this method. Lissajous curves come in the pattern shown in the red images in the Wiki link beenthere gave you.
yea i knw dat...even a circle is generated using two sine signals with a phase difference of 90 degree. so my question remains..how to generate a parallelogram?A function generator can only give you, as it says, a function. That means that if you draw a vertical line anywhere in the graph, it will intercept the signal only at one point. A parallelogram will be intercepted at two and thus isn't a valid time signal.
Do you by any chance mean a square wave?
http://en.wikipedia.org/wiki/Square_wave
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
