circuits
Discussion in 'Homework Help' started by MilkyTank, Jul 27, 2012.
  1. MilkyTank
    Jul 27, 2012
    13
    PLEASE HELP i need to know how to decrement and increment 7segment using the 7447,74192 and LDR :confused:
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    You can begin by showing us your circuit that you are working on.
  3. WBahn
    Mar 31, 2012
    18,091
    4,917
    What is LDR?
    While we can provide some hints and suggestions, a big part of the point of the problem is for YOU to figure it out yourself; it's the struggle from which you learn, more so than the end result.
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    LDR - light dependent resistor.
    I assume the op wants to count objects going by.
  5. MilkyTank
    Jul 27, 2012
    13
    this is the problem, i need to build a exit and entrance door and count the no. of people who enter the door at the same it decreases when somebody leave
    this is my tools:
    74192
    7447
    LDR
    7segment
    I dnt knw how to implement it :(:(
    please help
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Just have a look at the datasheets of the chips.
    Then you can see what signals are needed.
    If you want to determine the direction of the persons going in and out of the room,
    you will need TWO ldr's and make a circuit that can see the direction.
    Bertus
    MilkyTank likes this.
  7. MilkyTank
    Jul 27, 2012
    13
    thanks!!!!! but im confused about the connection between the 74192 to 7447 i hope you can help me
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have taken the pinout diagrams from the datasheets:
    74192:
    7447:
    Bertus
    Note: sometimes the pins are called different.
    A can be called A0
    B can be called A1
    C can be called A2
    D can be called A3
  9. MrChips
    Oct 2, 2009
    12,648
    3,458
  10. MilkyTank
    Jul 27, 2012
    13
    how can i put out the buttons and change it to LDR
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Imagine a circuit that creates a puls on the up pin when a person walks along LDR 1 and then LDR 2.
    Imagine a circuit that creates a puls on the down pin when a person walks along LDR 2 and then LDR 1.
    What would be needed to create such a circuit?
    Bertus
  12. WBahn
    Mar 31, 2012
    18,091
    4,917
    What about when two people are passing the sensors at the same time in opposite directions? Virtually every combination, including missed and overlapping hits.
    The OP said that he was supposed to have separate entrance and exit doors, so just use one LDR on each door. You have to assume that people come through one at a time and that you only get one interruption per person (not one for each arm plus one for the torse and maybe a leg thrown in).
    [/QUOTE]
  13. MilkyTank
    Jul 27, 2012
    13
    can anyone give me some schematic about my problem. Im very confused iin how to do it :confused:
  14. WBahn
    Mar 31, 2012
    18,091
    4,917
    Have you tried building any of the circuits you've been directed to? Or the circuit that you yourself posted (which has some problems, but it's a start)?
    Start by trying to just make a single digit count up or down in response to button presses. Once you have that working (and I suspect you are going to have some problems getting to that point), then it becomes much easier to do the rest.
    So build just the one-digit version using buttons and tell us what happens when you try to use it.
  15. MilkyTank
    Jul 27, 2012
    13
    i try to do it myself but it is not going smooth when it increase it always jump to far ex. 2 then 8 it always like that so that i try to see some other options
  16. WBahn
    Mar 31, 2012
    18,091
    4,917
    This is exactly what I expected you to see. I imagine that sometimes it jumps by, say, 5 and other times it jumps by, say 9.
    Have you ever heard of switch bounce? Well, that's almost certainly what you are seeing.
    So look up ways to debounce a switch. There are a few.
  17. MilkyTank
    Jul 27, 2012
    13
    debounce switch?? like this??
      File size:
      33.7 KB
      23
  18. MrChips
    Oct 2, 2009
    12,648
    3,458
    Debouncing an LDR is not the same thing as debouncing a mechanical switch.
    The dual NAND-gate circuit is the classic way of using a single-pole double-throw switch or push-button.
    (What you have there is an R-S flip-flop.)
    Except that circuit is incorrect. Both R1 and R2 should be pull-ups (to Vcc). 10kΩ is suitable for CMOS gates. For 74LS00 TTL gates, R1 and R2 should be around 1kΩ to 4.7kΩ.
    Debouncing an LDR sensor is a completely different story.
  19. MilkyTank
    Jul 27, 2012
    13
    then how can i put LDR back to the line?? =_=
  20. MrChips
    Oct 2, 2009
    12,648
    3,458
    The problem with the LDR is more about logistics than debouncing, as WBahn pointed out in post #12.
    You can condition the signal from the LDR with a retriggerable monostable multivibrator such as a 74LS123 to produce an extended signal of a suitable duration.
    The problem is that it does not identify the direction of motion.
    Then there is the problem of two persons passing each other, one coming in and the other going out.
    On a first iteration basis, you will need at minimum, two sets of sensors, staggered in position. One sensor will detect later than the other. From this you can determine direction.
