circuits
Discussion in 'The Projects Forum' started by pingo, Aug 20, 2010.
  1. pingo
    Aug 20, 2010
    How to convert sine wave into square wave without using transistors?????
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can use an IC, then a voltage comparator will work. If no semiconductors are allowed, then a vacuum tube might work.
    Are there constraints beyond no transistors?
  3. Bernard
    Aug 7, 2008
    4,231
    414
    Also diode clipper, & schmitt trigger.
