Circuits: trying to understand when to use parallel or series
Discussion in 'General Electronics Chat' started by vgamesx1, Apr 1, 2015.
  1. vgamesx1
    Apr 1, 2015
    Alright silly question... I'm planning on making a solar powered fan for a greenhouse, pretty simple right?
    Well since I already have several little cheap case fans thought I might as well use those, although one might not be enough, so if I were to add more, how should it be wired? or.. should I not even bother and look for a slightly more pre-done solution such as a fan splitter?
    I'm not very experienced so would appreciate some suggestions, also while I don't need help finding a solar panel, if you know of any you could recommend that might make searching easier for me, Thanks and here's a diagram of what I mean below.
  2. Reloadron
    Jan 15, 2015
    1,055
    275
    Case fans as in PC case fans? You have made no mention of what voltage or current the fans will be? What solar panel did you have in mind for this? You need a panel capable of supplying the required current for your fans and you need to have a total number of fans with data sheets specifications.
    Ron
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Two points:
    1) Due to 'load lability' series connection of fans is not advisable...
    2) The viability of parallel connection is 'down to' PS parameters...
    Best regards
    HP
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    How many fans you can run depends on your panel.
    Most of those PC fans run on 12Vdc. It would take a panel that has a direct-sun no-load output voltage of ~17V to properly run the fans.
    Do you have an adjustable DC power supply so that you can do some testing on your fans?
  5. vgamesx1
    Apr 1, 2015
    Yes PC fans, the usual 12v ones and they typically run off a mere 0.1-0.2 amps, so nearly any panel that supplies 12v should work. (times x fans of course..)
  6. vgamesx1
    Apr 1, 2015
    Its likely two or a max of four of them and I actually don't have a power supply but I do have one of those DC-DC buck step up/down converters, so I could possibly use that.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Not quite. Solar panels are basically current devices. The more current they supply the lower the voltage. Fans are likely to want more current as the voltage drops so you have things working against you. The suggested 17V solar panels allow you some headroom to design a voltage regulator that will supply the fans with +12V until the solar panel reaches the dropout voltage of the regulator.
  8. vgamesx1
    Apr 1, 2015
    Right, I just meant the panel wouldn't be much of an issue, Thanks though I'll try to find something about 17v then.
    Also Thanks HP circuits are the main thing I have trouble understanding, I dunno why it just confuses me a lot.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Just remember two simple rules
    1. A series circuit has the same current flowing through each element. It is a constant current arrangement.
    2. A parallel circuit has the same voltage across each element. It is a constant voltage circuit.
  10. wayneh
    Sep 9, 2010
    12,405
    3,256
    I would add a third simple rule: Regardless of current and voltage match-up, the power needed by your fans cannot exceed the power capacity of the panel.
    Your fans need ~1.5W each. So for instance you can forget about using more than 3-4 of them on a 5W panel.
    Papabravo likes this.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would expand on that to stress that you cannot get more power out of a system than you put into it. This is especially true of Switched Mode Power Supplies (SMPS).
  12. wayneh
    Sep 9, 2010
    12,405
    3,256
    There are no degrees of "True". There is only truth. ;)
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Which most people doggedly refuse to accept inspite of overwhelming evidence.
