Circuits Please help
Discussion in 'Homework Help' started by peter22, Jan 5, 2007.
  1. peter22
    Jan 5, 2007
    Hi Everyone
    Can someone please help me as I'm truly stummped.
    I'm trying to work out the current at the 40 Ohm resistor
    Id appreciate any help
    regards
    Peter22
  2. peter22
    Jan 5, 2007
    would i be right in saying that its 10v going through E and 20v going from A into the resistor?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you required to solve it using a specific method (i.e. Kirchoff's Voltage Law, Superposition, Millman's Theorem, etc.)?
  4. peter22
    Jan 5, 2007
    I think probably using Kirchoffs law, i keep reading over it and its still not sinking in
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    The circuit you have been given can be redrawn into the form shown in the Example Circuit presented in the AAC Tutorials section of this website. I suggest you study the example and its solution and see if that will help you in solving the problem you have before you.
    Once you have reviewed the example, take a stab at applying the technique to your specific circuit and post your efforts. I am sure that one of our members will be more than happy to assist you in determining where you may have veered off the path with your equations.
    hgmjr
  6. peter22
    Jan 5, 2007
    Thank you for your help
