--from your other thread on exactly the same topic...How can one design a PCB, yet not know circuit design?
Gotcha, well, as suggested, the ebook here is a nice place to get into the topics, but it isn't the best resource once you get the ideas down.i do the layout deign the inputs are schematics
At what level did you do the layout? Did you just feed the schematics into an autorouter and package the results to send to a board house for fabrication? Did you take the schematics and make the decisions about which nets were timing critical, which nets needed to be routed together, how the ground planes should be set up and, if necessary, split, and how to layout the board to achieve EMC compliance? Or something in between?i do the layout deign the inputs are schematics
by Duane Benson
by Aaron Carman
by Jake Hertz
