CIRCUIT
Discussion in 'The Projects Forum' started by speeed_777, Mar 21, 2009.
  1. speeed_777
    Thread Starter Active Member
    Oct 5, 2008
    54
    HEY,ANYONE KNOWS CIRCUIT FOR VOLTAGE STABILIZER(AUTOMATIC CONTROL OF HIGH VOLTAGE)?:(
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Such a thing would depend upon the requirements.
    What kind of voltage (DC, AC) and current or power are you talking about?
  3. speeed_777
    Oct 5, 2008
    54
    A.C AND VOLTAGE
    AS ONE SUCH DEVICE I HAVE USED IN MY COMPUTERR INPUT PIN
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    So you're wanting to regulate an AC voltage.
    What is the peak or RMS value of the AC voltage that you wish to regulate?
    What is the current or power required?
  5. speeed_777
    Oct 5, 2008
    54
    I DON'T KNOW EXATLY WHAT IS MEANING OF RMS VALUE.BUT NORMAL VOLTAGE RATING IS AT 230V,50HZ AC.
    (It often goes at 280-290v.But due to stabilizer it controls to 240v)
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    RMS = Root Means Square.
    A sinewave is sampled for voltage levels, the square root of those samples are calculated, then the samples are averaged together, and the result is squared.
    If the sinewave is a perfect sine, an approximation of the RMS value can be calculated by multiplying the peak voltage by 0.707107.
    If you already have a stablizer, but it's output voltage is incorrect, then it needs adjustment. The manufacturer should be consulted as to how or where you can get it repaired/adjusted properly.
  7. speeed_777
    Oct 5, 2008
    54
    Thanx for your response.I have one other discussion also,plz Wait for my next thread
