'Circuit Wizard' design software
Discussion in 'General Electronics Chat' started by studiot, Nov 22, 2010.
  1. studiot
    Thread Starter AAC Fanatic!
    Nov 9, 2007
    5,005
    515
    Anybody tried this product?
    Comments please.
  2. Ctenom
    Member
    Nov 1, 2010
    59
    I got myself a copy from maplin a while back. Its a brilliant tool for beginners however if you have a decent knowledge of electronics you will find it limited in IC's it has only the most common ones. Click the library tab on their website for a list of the ones it has. it also has some small problems with other things as well eg it will let you run a circuit with just a voltage regulator and no power input. you can put thousands of volts though leds and other components and they don't break just light up like every things fine. All that aside it is a good program but only if you have limited knowledge and still its probably not worth the £60. They have a demo version available on their website if you would like to check that out otherwise go grab your self a different freeware program their are loads out their. And if you have a Android phone electrodroid is a brilliant app to have handy.
  3. nigelwright7557
    May 10, 2008
    488
    71
    I tried it briefly and didnt like it at all.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There are more than one "Circuit Wizard" products available.
    I suggest that you include the publisher's name, or better yet a link to the site to provide disambiguation.
    This "Circuit Wizard": http://www.new-wave-concepts.com/ed/circuit.html
    looks to be quite limited.
