Circuit with 3 Zener diodes!
Discussion in 'General Electronics Chat' started by ENG99, Aug 27, 2015.
  1. ENG99
    Feb 13, 2014
    37
    Hey, I got a little confused and I wish I can get answer! Now, if i have a circuit with 3 diodes (9V, 7V, and 5V) is that true one of them must be on which is 9V and the other have to be OFF?
    Thnx
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    My crystal ball is in for a tune-up, so I'm also confused.
    Can't answer your question without a circuit diagram to see how you connected them.
    DerStrom8 likes this.
  3. nsaspook
    Aug 27, 2009
    3,015
    2,370
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
  5. Ancel UnfetteredOne
    Member
    Jul 3, 2015
    36
    14
    Diff. Voltages mean zener diodes i believe.
    If they are in series AND rev. biased....they add up to create a total required voltage of 9+7+5 for them to switch 'ON'. They will all be on for current to flow....vis a vis Kirchoff.
    If they are all fwd biased, in series, they will all be on with a small voltage supplied. Much smaller than 5V, perhaps 1.8V.
    If the are in parallel and again rev. biased, the lowest value will switch on first clamping the voltage and preventing the others from conducting.
    Being zener diodes your circuit WILL require a current limiting resistor to perhaps limit the current to a few mA, else you can burn the parts.
    In fwd biased parallel (and with a current limiting resistor) the voltage across them will be clamped to around 0.6V...a single silicon PN junction Vf.
    Hypatia's Protege and ENG99 like this.
