I need help wiring the following circuit board. I've attached it as a jpg. I'm brand new to this, so detailed information about components will be great.
No need to apologize. When confronted with a problem, theI apologize for not being clear.
What is the approximate range of time needed for the pump to run?(I don't know the exact amount of time needed to inflate it, so I'll need to be able to adjust the amount of time that the pump is on.)
How it is done will depend on what components you have access to.When the circuit is powered, I was wanting to use the potentiometer as a switch. When it is turned to a certain point, the pump will be turned on. (this will be more or less a simulation, so the set point can be set to any particular value)
The details will determine whether it is elementary or not.I know this is probably something elementary, but I'm brand new to circuits, so I need to know how to wire and program it. (I'm a visual learner so a diagram would be great.) Thanks!
by Jake Hertz
by Duane Benson
by Jeff Child
by Aaron Carman
