Circuit to measure signal strength
Ubergoober
Joined Aug 5, 2008
9
I need a to make a circuit that measures signal strength, something for a amp project. I need to know in how many volts my output is. Thank you so much for helping.
Ubergoober
Joined Aug 5, 2008
9
Sorry if I didn't explain myself clearly. I want to make a sonar distance meter (just for a meter or two) I will have a speaker transmit a 50khz signal and then the mic listens for the echo. I hope by listening to the echo I can determine how far away the object is. I will use a PIC16F57 to do all of that, my only concern is how get the highest part(in voltage that is) of the signal.
mik3
Joined Feb 4, 2008
4,843
You mean you want a peak detector?
To measure the distance you need to measure the time the sound needs to travel from the speaker to the mic.
flat5
Joined Nov 13, 2008
403
To measure the distance of a few meters, line of sight, I have an idea.
Use a LED transmitter/receiver and an audio transmitter/receiver.
At the receiver end, use the LED circuit to start the timer and the audio circuit to stop the timer. Convert the result to distance.
Audioguru
Joined Dec 20, 2007
11,248
If you use the signal strength of the reflected signal then you are measuring how smooth, hard and aimed-at-you the surface is, not just its distance.
