Circuit to find maximum of three binary numbers?
Discussion in 'Homework Help' started by Blackrobe, Oct 30, 2009.
  1. Blackrobe
    Oct 30, 2009
    6
    Hey there,
    I have to build a circuit that finds the maximum of three binary numbers given. The circuit should go through all three inputs at once. I was wondering how to find the maximum of two binary numbers for example 1001, 0101. I don't need a solution i just need some tips/hints or any help to get me started is fine. thanks a lot
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You may want to take a look at the 8-bit magnitude comparator 74HC688.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The IC for comparing the magnitudes of 2 four bit words is the 74LS85. That might give you a hint if you look at a data sheet.
