I replaced the LED with a smaller one and added the resistor in series with it. I also replaced the IC in case the output was burned out. Still nothing. Any ideas? I'm getting pretty frustrated with it at this point.
You can refer to the image of how to hook up the circuit. I have numbered the pinout of each inverter inside the CD40106B. I also included two LEDs, each with a 220ohm series resistor. This is not shown in the circuit diagram.I am as sure as I can be that it is all hooked up right. The polarity on the LED is correct. I am going to tear it all apart and start fresh tomorrow.
A dot is small depression, a little bigger than the "period" on the keyboard. It will be off-center and very close to pin#1.There is a notch on one end of the chip and a dot on the other. So which end is considered "1"?
The circuit is to be powered continuously.Applying power to the "input" (the wire attached to pin 3) doesn't seem to change the state of the circuit no matter what length of time it is applied.
No.Can I use the 2 independent spots vs a single spot and a common ground? I hope my description is clear enough.
To overcome this voltage problem you would need to add a transistor. The changes are marked by blocks of light blue color.So I guess I need to figure out how to turn 2 volts into something large enough to trip the circuit I've built.
What function is this LED suppose to indicate?So now I have to figure out the best way to turn a blinking LED into a 12 volt signal. Are transistors the best way to do this or would a relay be better?
Good. You would need to switch about 1.5A then.The resistance is 8.5 ohms according to my multimeter.
by Jake Hertz
by Duane Benson
by Robert Keim
by Jake Hertz
