Circuit theroy
Discussion in 'General Electronics Chat' started by Atharmahmood, Nov 28, 2012.
  1. Atharmahmood
    Nov 28, 2012
    Which condition we use kvl and kcl therom .and also tell that about super mesh
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Use KVL is summing voltages around a loop appears to be useful.
    Use KCL if summing currents at a node appears to be useful.
    Use a supermesh to enclose two (or more) meshes when you have a common branch within the supermesh for which you know the current relationships between the meshes but not the voltage across the branch. A current source in the common branch a common case where this might be true.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is more of a electronics problem, and we have a forum for that, so I moved this thread to a better location.
