Circuit Theory Problems
Discussion in 'Homework Help' started by Khan_01, Mar 27, 2007.
  1. Khan_01
    Mar 27, 2007
    Hi;
    Plz help me in the attached problems of Circuit theory. I'll be very thankful.
  2. nomurphy
    Aug 8, 2005
    567
    12
    Reduce into simpler circuits.
    Look for resistors in series, and simply add them together:
    Rt = Rx + Ry : (150 ohms = 100 ohms + 50 ohms)
    Look for resistors in parallel and use the following:
    Rt = 1 / [(1/Rx) + (1/Ry)] : (33.33 ohms = 100 ohms || 50 ohms)
    : when using a calculator for parallel resistance, just invert (1/x) any resistor values, add them together, then invert again.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Go ahead and post your efforts to solve any one of the problems and then the members can assist you with any errors that are keeping you from getting the correct answer.
    hgmjr
